Found a CR rake, anyone have a good jack?
Alan K
This followed me home. The jack does work but is bent and not sure how they are held in transport. Anyone have a good close up picture of the jack? Are the teeth the same as New Holland or New Idea? I do remember they had a bracket for a hydraulic cylinder but how is the cylinder attached at the top? Now all I need is some hay lol.
Great find Alan, to put a jack on mine,I made a bracket to bolt onto the right side of the frame and atrtached the jack to that.IF I ever find a good jack, I can unbolt the bracket and install the jack.It uses the most common NH teeth, either rubber or spring.The origionals are very different but I've had no luck findiing them.
