Removing flywheel from 185 MM
G1355
So I started tearing apart my 185 I bought have everything apart exept the flywheel and crankshaft, only way crank looks to come out is the back, but I can't get the flywheel off, I took the big nut off 2-3/4" nut came off fine, but behind that is what a call a nut you tighten with a hammer and a chiesel but it doesn't look threaded or doesn't move when I use a chisel and hammer. How do I get the flywheel off? Flywheel doesn't have grooves if that matters because its hand crank only no starter. Thanks.
Take the starter hole cover off and insert a long crowbar into the hole behind the flywheel. Keep rotating the flywheel and rapping the crowbar against the back side and it will come off.
