BG Question?
breadman2126
New User
Can anyone tell me if the BG was ever equipped with a PTO? I see in the tractor data on this model it shows a belt pulley. If it did, is the housing for the PTO and belt pulley the same that was used on the BF?
Thanks,
Steve
Serial number 637 has 540 pto but no belt pulley. I don't think it even has the belt pulley shaft in it. It actually had a 4 ft. bushhog on it when I bought it. So I guess its standard rotation.
I do not know if its the same housing as BF or not, I was thinking the BG belt pulley came out the other side from the BF. I Guess I will have to compare it with my Avery R.
The housings do bolt to the same transmission case casting.
