Utu intake manifold
1948 mm
I just recently converted my utu lp from ensign to impco. Everything went well and all works well. I would like to put a larger intake manifold on it to match the larger (1 3/4") carb I have on it now. I have a g intake manifold which is bigger but it is longer from the heads out which interferes with the side panel of my utu hood. Is there anyone out there who makes a bigger manifold or is there a manifold off of a newer mm that is short and would work. The stock manifold I am running is only designed for a 1" carb and I'm sure there is some power to gain with a larger manifold. Thanks
An "M5" lp fits close to the engine. It is a "Y" shape rather than the manifold you currently have that is made with the 90 degree bends. Used on both gas and lp models from M5 and newer to some degree. If my e-mail is available (I tried); I do have some I will sell.
