U302 with White348 plow pics
Anonymous-0
After getting the 302 to be able to pick it up I decided to fix up
the plow. Finally got it done. Going to display it at the fair next
week...hopefully I will have the 302 done next year. I only
made one mistake....and I'm sure someone will pick it out
pretty quick! Considering selling the plow now since it's way
more plow than I need, and I'm sure it's gonna work the 302
hard once I try it in the ground! I replaced all of the wear parts
so it's now like new. I added a couple before pics too. I have
600 pounds on the front, and if I stand on the back bottom and
bounce the front wheels get light! It is one heavy piece.
You caught the mistake. Got in a hurry. Waiting on new decals because that is all I see when I look at it!
They offered a gauge wheel for this plow which rode on the land side. According to the owners manual they did not use a tail wheel.
I saw that too, when he said it. the White "W" goes first, black "W" second. Think White (white) Motor (black/oily). Don't feel too bad though, I've seen them wrong from the factory, even an MM implement with an upside down MM = "WW" before. ;) It looks great, you did a great job on both the tractor or Plow.
Looks a like a good plowing outfit. I"ve used the 5 bottom years ago. Have you tried plowing with it yet? If it feels like too much maybe drop a bottom.Wonder if you can still get parts for them?
One thing I would suggest is to utilize the "rate" of drop lever when you try it out. Wouldn't want that thing bouncing too much. Make sure you post pictures when you do.
