Anonymous-0
I am using the OEM gauges on my 66 U302. I replaced the temp sending unit due to the original not working. Now the gauge only registered slightly up in the cold band of the gauge after working the tractor pretty hard (I'm sure it's way warmer than where the gauge shows). Any ideas? Maybe I put in the wrong sending unit? Does anyone know which sending unit is correct for the 302? Also the gas gauge bounces between empty and 1/4 tank no matter how much gas is in it. I have checked all of the connections, and pulled the original sending unit out of the tank and inspected/cleaned it, but still no luck. Just trying to keep the original gauges, and know the information is correct. Thanks
