PaulGrassick
New User
I know that this topic has been discussed before, but I am still looking for some advice before I invest in a 50 gallon drum of oil. I am about to change the transmission/differential oil in a Vista and a Wheatland. I have always used Castrol oils and their recommended transmission/differential oil for for these tractors is Castrol AS Agri Trans Plus. This oil is a 20-30 wt oil, and I think similar to the Hy-Trans and Hy-Gard oils used and recommended by many. These oils all seem to have similar viscosities at temperature ranges from 40 to 100 degrees centigrade. And all are combination transmission/hydraulic/wet brake oils.
While many Moline manuals do not recommend a specific oil viscosity for the transmission/differential, the older manuals for the M5 and M670 do recommend that the oil should be SAE80.
Since the oil in the rear end of these tractors does not have any hydraulic function, and these tractors have dry brakes, should I use the combination type of oil or go back to an SAE 80 wt oil? If there is a benefit from using the thinner combination type of oil, what is it? And as these tractors also have transmission oil coolers, which type of oil would be more effective in dissipating heat? And which type is best for the TA?
Seems lots of questions I know, and maybe the answers will give me the peace of mind I am looking for. One point to note is that I am in Australia, and these tractors never see temperatures below freezing.
