vista parts
Need to know where to buy good use or new parts for G 1000 VISTA, like emblems, fasteners for the front grill, battery holder/covers , nuts/bolts, or anything for VISTAS , thanks Marty
If you have the earlier Vista with the same battery cover as the G705-708s like this, I make reproduction ones of them, along with the "J" bolts that go on them.
If you go with the original style batteries on the Vista, they would be two of the long skinny batteries in the battery box. Not sure but Im guessing 3EE. I believe they originally had four 1/4" studs that were welded to the battery box, 2 on each end. I have a picture in a manual some where that shows the cover in place. The covers I make are made of 18ga steel. I can get you some measurements on it but it might be a day or two.
Here is a picture of the bolts I make, which were taken from an original for a pattern. The original length on them are 8" top to bottom. I make two different sets of them. The 8" ones are for the 3EE batteries and some that are 9" for the 3ET batteries, as they are about 1/2" to 3/4" taller. I will see if I can find the cover picture I was talking about and post it later this evening.
Here is the picture I was referring to. Most of them I have seen had a pair of studs on each end, unless they started out with the J bolts and changed them later. I can get a measurement for you between the holes so you can compare them with the ones in your battery box.
I would be interested in a set of the Vista emblems- are they reproductions and what it the price.
