585 oil pressure, and hydralic pump noise
G1355
My 585 will run about 55 pounds of oil pressure when its warmed up, but it only gets about 140 degrees, think it should be a about 45 pounds and warmer but will it hurt anything running cooler and more oil pressure, I know these motors have oil pressure problems anyways and don't know if to much hurts, it has internal pump which I know the external is better but I don't have one, and my hydralic pump is pretty quiet at a idle but about 1300 rpms its noisy if standing beside it, driving it you don't notice it, but if you rev it past 1500 it quiets back down, is this normal?
If I were running a 585 with an internal oil pump I would wire an automatic oil pressure shut down switch so it would kill the engine if the oil pressure failed. Just because I had a bad experience with one running a silage chopper once.
