Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Marvel Carb throttle shaft cause this?
07-30-2014 07:58:58
Sounds like your are shooting in the dark. The kits I sell have throttle shafts seals and instructions. Anyway. Float level should be set as follows. Turn the top half of the carb upside down, leave the gasket off, install needle and seat, and float. Take a 5/16 stock round rod and place it under float directly over the throttle shaft, both sides of the float should lightly touch the rod. The Idle screw and the load screw should be turned in to lightly touch the bottom of the seat and then turned out 1 to 1 1/2 turns. Adjust from there to fine tune with tractor running.
