Pics-Friends Recently Restored UB MM
1206SWMO
My friend Robert recently finished up his UB MM...I found it for him in August 2013 sitting in a river bottom about 30 miles away....Several times flood water had been half way up on it but never got in the engine..
The 705 blocks had deck plates under them with different rods plus it had been bored .060 so was 336 cubes plus...It should be pretty strong...All it needed was rings and a valve job as the bearings were OK...The shifter lever was broken off and the front pedestal was split open...Some new axle and brake seals were installed...Several trips to Welters fixed things..
Robert was a JD and AC man but I and a friend talked him in to getting several MM's and he now has 3 restored ones (UB,U,ZA) and 3 more to restore...The first picture shows it in the river bottom and the last two pictures were taken yesterday..
Kinda too bad how some people just leave them sit and to think that was a big tractor in its day, like pictures of how it was and how it is now great job and thanks for sharing
Nice lookin'. First UB I have seen with a belt pulley, does it also have a PTO? Or is that possible? Mine and parts buddy are both PTO only. My Vista came from near a lake and it had been deep enough to get water in the brakes.
Bryce
Yes,it has a PTO....I might add that new rear tires were put on
it many years ago and the tractor was barely used after
that..Sitting under a tree helped shelter it..
Do either run I'd love to buy the g1350 would rather have a diesel but wouldn't mind propane, what state are they in
