TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Wierd smoke
ColeHans
07-07-2014 10:54:10
I have a jet star 3 super that when it runs and is shut down it has a white smoke pour out of the hood, it doesn't smell like burning oil, belt or antifreeze, it doesn't heat up past 170 what could it be?
DPinkley
07-07-2014 17:27:55
 Re: Wierd smoke in reply to ColeHans, 07-07-2014 10:54:10
If it's white, I would bet it is coolant. Is it a pressurized system? It may be squirting out onto the manifold from a leaky gasket or hose. I was running my W-30 MD one day & I could feel a mist every once in a while. I finally got to looking & the head gasket had split at the cylinder ring. It was non-pressurized, so when it went into compression it would blow coolant out between the gasket layers to the outside.
ColeHans
07-08-2014 10:11:42
 Re: Wierd smoke in reply to DPinkley, 07-07-2014 17:27:55
Yea I thought the same but I don't lose any coolent. I'm going to take the hood off tonight or tomorrow and see if I can see more
Alan K
07-07-2014 12:36:35
It could possibly be coming from the crankcase breather. That is a place I would check as it might be blow by.
ColeHans
07-07-2014 13:32:04
 Re: Wierd smoke in reply to Alan K, 07-07-2014 12:36:35
Alan K said: (quoted from post at 12:36:35 07/07/14) It could possibly be coming from the crankcase breather. That is a place I would check as it might be blow by.
It's coming off the manifolds, and it only does it when it's hot, I have taking the oil cap off to see if it was blow by but it is not blowby
This post was edited by ColeHans at 14:33:43 07/07/14.
Majorlucas
07-07-2014 13:35:52
 Re: Wierd smoke in reply to ColeHans, 07-07-2014 13:32:04
Is your carb icing up and then dripping as it thaws?
ColeHans
07-07-2014 13:56:50
 Re: Wierd smoke in reply to Majorlucas, 07-07-2014 13:35:52
Just above gets frosty but not iced
