moline m5 heads and jugs
Heads are universal. No one specific head used on any particular tractor. Jugs will have a different casting no.. I not positive but U jugs ended w/the number 49.
The M5 blocks I put on my U are 10A15154. I used the heads that were already on it. If you want I can get the numbers off them.
Look for a spacer or multiple gaskets between the jugs and crank case. The M5 jugs are slightly shorter than the U jugs. Internal pats can be changed to eliminate this though. As stated below heads are interchangeable between all of the tractors for the most part. With head studs and push rods changed accordingly to match the proper height.
(quoted from post at 21:53:17 06/24/14) The M5 blocks I put on my U are 10A15154. I used the heads that were already on it. If you want I can get the numbers off them.
hat is the number on my blocks. If you could let me know what your head numbers are?
