TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
moline m5 heads and jugs
moline u
06-24-2014 08:36:24
How do you identify m5 heads and jugs already on a u moline block?
Tim Yates
06-25-2014 02:20:25
 Re: moline m5 heads and jugs in reply to moline u, 06-24-2014 08:36:24
Look for a spacer or multiple gaskets between the jugs and crank case. The M5 jugs are slightly shorter than the U jugs. Internal pats can be changed to eliminate this though. As stated below heads are interchangeable between all of the tractors for the most part. With head studs and push rods changed accordingly to match the proper height.
Larry Mi
06-24-2014 13:53:17
The M5 blocks I put on my U are 10A15154. I used the heads that were already on it. If you want I can get the numbers off them.
moline u
07-02-2014 20:55:54
 Re: moline m5 heads and jugs in reply to Larry Mi, 06-24-2014 13:53:17
Quoting Removed, click Modern View to seethat is the number on my blocks. If you could let me know what your head numbers are?
mmfan55
06-24-2014 09:49:33
Heads are universal. No one specific head used on any particular tractor. Jugs will have a different casting no.. I not positive but U jugs ended w/the number 49.
