G1355 brake leaking oil badly
d21smith
Recently got my 1355 running and finally got the clutch loose with help from the old girls brakes but now the left side leaks a lot of oil and the right side as well some. I'm curious any suggestions as to what it might be? Seal or oring? Just wondering before I get Into it . The brakes still work I just need to fix the oil leaks thanks for all the help so far
I believe the first thing I would do is check the fluid levels in the tranny and rear end, if overfull it is going to leak somewhere. Loosen the drain plugs to verify there is no water in the bottom to make the levels too high.
Bryce
Your brake lining are wore out and this lets the brake piston come out of the cylinder to far and you will get a bad leak when you step on brakes.
I know when mine were leaking they replaced alot of stuff, would have to dig out my receipt of work they did, I know they put in seals and there was quiet a list but I will check tomorow if I find my receipt and tell you what mine all had put in it.
It's probably hydraulic oil leaking out of the large O-ring on the brake piston. Pretty easy to replace. After setting as long as your tractor did and you say you stepped pretty hard on the brakes to get the clutch loose I would bet you blew out an old O-ring.
