what is this 504 engine from?
found a Minneapolis engine for sale, the serial number tag shows the model as D504A6. and serial no. 29701227.
any ideas what this engine was originally in? will it bolt into a GBD? what might not fit?
thanks,
russ
Im not sure about a gbd but there is an older post involving interchangability that says it should. If im correct a gbd used a 451 so it should fit from what I can find out but ive never done it.
i dont think the 504 will fit a GBD. i was told the 504 is a small bell engine and a GBD has a big bell housing. thats why the HD800 will fit the GBD cause it is a big bell. the 425 and 605 are big bell engines. it sounds like it is out of a G1000 cause i had a guy want to my a 605 i have but he said he needed a small bell engine and he wanted a 504
I agree that the 504 diesel from a G1000 would not fit because it would be a small bell. If the 504 were from a 705, 706, 707, or 708 it would fit. The hand clutch 6 cylinder diesels used a large bell, and the later G1000, G900 series have a small bell.
So if the bell housing is different, Can u use the heads,
pistons, rods and blocks off it and bolt them into my original
425 crank and case?
Im gonna show some ignorance here but im gonna ask a big
bell and small bell im assuming is referring to the belt housing?
The letter and m series is big bell and g series is small bell ? Do
I have this right?
There are big bell 504s, that"s what"s in the G-705 and up. Also there were some HD 504 power units, those would also be "big bell" engines.
I have this right?
