Anonymous-0
After months of trying to figure out why ( in my novice MM tractor mind) my U302 wouldn"t pick up the White 348 plow I finally got it. Needed the right gauge to check pressure, and then set the relief valve spring tension right. Went from 1000 PSI to the recommended 1600 PSI. Picked up the plow no problem! I had another good moment today too. Drove the 302 to a friends to mow a pasture for them. Finally it has dried up enough in central Ohio for everyone to get back into the fields. On the way home I passed a guy driving a new huge JD 4 WD working ground. I waived, and he waived back and then gave me a thumbs up, big smile, and nod. Nice to see someone else appreciate the 302 like I do!
