mounted corn picker
Any interest or what might it be worth? Lady said it was on a R Moline
It's an Oliver built 74-H. Not sure what Moline's number for it was. Where is it located? I would say between $500 and $1000 depending upon the mechanical shape. I don't know, that seems to be an awful big picker to be on an r Moline. Most were made for the Oliver 1650-1850's etc.
This picker was likely made to fit U302, M670, and several later model Oliver tractors from 770's on up. This style was an Oliver 74H that was painted MM yellow. Could go on alot of different tractors tho. I tried buying one off a Farmall M a few years ago. The picker that fit the M5 and 4 Star was the SK "Rock and Roll" picker you backed underneath. The ones that fit the UB were "RJ" pickers that were two piece.
Go to YouTube.com and type in Minneapolis Moline Picker at Walnut, Illinois and there is similar picker mounted on a M670 Super and a few other videos of same.
Yes this is an Oliver picker. MM # is H210. Too large for an R. Would fit M5, M602,M670, M670 Super, as well as competitive tractors.
Lady said it was on a R she used to run and the R is still there i couldnt find a S/N or tag to say who or what it was she is located in Southern Wisconsin if you are truely intrested please email me at [email protected] and we can go from there
(quoted from post at 11:00:15 05/09/14) This picker was likely made to fit U302, M670, and several later model Oliver tractors from 770's on up. This style was an Oliver 74H that was painted MM yellow. Could go on alot of different tractors tho. I tried buying one off a Farmall M a few years ago. The picker that fit the M5 and 4 Star was the SK "Rock and Roll" picker you backed underneath. The ones that fit the UB were "RJ" pickers that were two piece.
The SK "Rock & Roll" was probably easiest picker to mount, ever.Simply back under ,roll down and hook up 3-pt and pto. 3-pt raised picker. Had medium capacity.
