moline plow
hrRoss
i just bought a moline 4 bottom trailer plow. it has the main beam there to accomodate 5 bottoms. the problem is getting the 5th bottom there to complete the plow. this plow has the bottom beam that goes all the way to the front where they all fasten to the hitch bar. any help finding the extra bottom and related parts would be helpfull. bear in mind that this bottom needs to be the 5th bottom as it would be longer than the 4th,3rd, etc. thanks hross @920-562-7890
I think those plows were the same as the 2,3,4 bottoms. The base 2 bottom can be made into a 3, the base 3 into a 4. If I remember right the "extra" bottom on any of them never went all the way to the front, it bolts on the side and the small "I" beam went over the top of it. They were braced in between like the other bottoms. The hardest part would be finding the longer "I" beam for it as that would be partial only to the 5 bottom.
alan, i have the I beam on the plow for 5 bottom, its sticking out past the tail wheel. someone was runnung it as a 5 bottom at one point but took off the 5th bottom and used it as a 4 bottom.i want to return it to 5 bottom. need the extra bottom parts.
I will have to look in some literature but I think you should be able to get the extra bottom from most any of those plows as long as it and the bracing between the bottoms matches your width (14" or 16"). Knowing MM Im guessing they used the same parts. I have a plow book or two, I will see what I can find out for you.
I've got some add on plow beams jere in IL/WI Lake Michigan area. I think they are all 14" though. eight four seven 309 7347
