TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Resleeved big bore blocks/ pistons
jmho
05-08-2014 15:00:38
Where can a guy find resleeved big bore blocks (5.5") amd how much do they cost? What is the best thing for 5.5" pistons? How much ruffly would 5.5" pistons cost ?
mmfan55
05-09-2014 16:30:39
 Re: Resleeved big bore blocks/ pistons in reply to jmho, 05-08-2014 15:00:38
It is possible to bore and sleeve any of the Moline jugs. Currently have "U" jugs @ 5.5; also had "403" jugs @ 5.5. Both have water running thru them. Cheapest route on pistons is Caterpillar 3406; (5.4")- or 855 cummins (5.5). Used pistons will be cheap but you will have to spend money to machine them to work. (that is the "shadetree" approach.)
jmho
05-09-2014 16:19:35
Thanks for the replies guys. I just talked with a fellow who is going to hook me up with a set and pistons.
Jeff Gravert
05-09-2014 06:34:37
If you are going to spend the money to do such a project, there is no reason to stop at 5.5".
Dieselbear
05-10-2014 11:11:04
 Re: Resleeved big bore blocks/ pistons in reply to Jeff Gravert, 05-09-2014 06:34:37
My solid blocks will go to 6" esay
H Dean
05-10-2014 15:02:18
 Re: Resleeved big bore blocks/ pistons in reply to Dieselbear, 05-10-2014 11:11:04
Dieselbear how can you be reached?
Doug Cotton
05-08-2014 18:41:00
If you decide you can use HD800 pistons, I have a new set of .020 pistons I would sell. My cell is 231-564-1039
Dieselbear
05-08-2014 18:00:29
short or tall blocks
jmho
05-08-2014 18:25:56
 Re: Resleeved big bore blocks/ pistons in reply to Dieselbear, 05-08-2014 18:00:29
Tall blocks, can't run 800 parts and heard of ones resleeved to have water in them
Dieselbear
05-09-2014 03:58:28
 Re: Resleeved big bore blocks/ pistons in reply to jmho, 05-08-2014 18:25:56
You are talking about G blocks that had sleeves welded in? most end up filled with hard block
Tim Yates
05-08-2014 17:10:01
Use HD800 blocks. Can bore to 5.5" and still run water. Expect $1200 for a set of 4 with rings and pins.
jd plowboy
05-08-2014 15:12:25
you looking at a lot of money.
