TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 445 Governor
CAPTAINHOOKERUS
05-08-2014 13:09:13
Unhook the rod from gov to carb. Pull throttle lever to wide open position. Adjust rod so it will go back into carb lever or gov arm which ever you end you removed. Then adjust spring tension to get desired RPM.
majorlucas
05-08-2014 13:54:54
 Re: 445 Governor in reply to CAPTAINHOOKERUS, 05-08-2014 13:09:13
Thank you! That seems like a much better way than simply guessing whether to lengthen or shorten it!
I'll let you know how we do!
Marty
CAPTAINHOOKERUS
05-09-2014 13:02:06
 Re: 445 Governor in reply to majorlucas, 05-08-2014 13:54:54
Marty after reading my post I left out to also hold the carb shaft in wide open position while adjusting rod length.
majorlucas
05-09-2014 19:15:25
 Re: 445 Governor in reply to CAPTAINHOOKERUS, 05-09-2014 13:02:06
Following your guidance, she is running better now. Lots more power, but still a little weak. I need to put an accurate tach on it to see what RPM she is set for.
At least I am able to get a little work out of her now!
Thanks!
