u parts problems.
jr1983
I am looking for the bushings springs and weights to repair the
govoner on my u.it works and have adjusted it as closely as I can
but it seems sluggish in operation. It occasionally sticks and I
have to throttle it back down because it revs up to far.I am also
in need of a brake adjuster. Agco can get them but I would like
to find an aftermarket source for brake parts if it was possible.
I think Motec Engineering rebuilds governors yet, although I don't have his contact info. If you have a way to do it I think a guy can buy starter bushings that might be the same to rebuild yours. As far as the brake adjuster, "U"s are quite common as was a lot of the brake parts so finding a used one shouldn't be a problem. I can see if I can find some contact info for you.
Matt Gall or MOTEC Engrg & Rest is at
7342 W. State Rd. 28
Tipton, IN. 46072-9001
765 963 6628
motecengr dot com
