MM Hydraulic Cylinder ("Z")
Joe Pro
Does anyone have a parts diagram or list for the older mm hydraulic cylinder that would have been mounted on a ZA. I need some part numbers, we've got two here with broken rods.
Thank you
Well I'll try again
Casting number on cylinder should be 10A79, just to clarify. 10A80 will fit but is sized for larger tractors.
(quoted from post at 22:04:26 05/05/14) What part numbers you looking for. 2 1/2 or 3 1/2 cyl. both were used for R Z and U tractors.
2 1/2 inch cylinder with a large cast rod end clevis.
