Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
MM Hydraulic Cylinder ("Z")
Joe Pro
05-05-2014 08:49:03
Does anyone have a parts diagram or list for the older mm hydraulic cylinder that would have been mounted on a ZA. I need some part numbers, we've got two here with broken rods.
Thank you
shinnery
05-05-2014 17:36:37
 Re: MM Hydraulic Cylinder ( in reply to Joe Pro, 05-05-2014 08:49:03
That must be an Australian parts list...
Joe Pro
05-05-2014 13:39:29
Yes it is except I can't see it :(
Larry Mi
05-05-2014 18:04:26
 Re: MM Hydraulic Cylinder ( in reply to Joe Pro, 05-05-2014 13:39:29
What part numbers you looking for. 2 1/2 or 3 1/2 cyl. both were used for R Z and U tractors.
Joe Pro
05-06-2014 05:45:08
 Re: MM Hydraulic Cylinder ( in reply to Larry Mi, 05-05-2014 18:04:26
2 1/2 inch cylinder with a large cast rod end clevis.
Larry Mi
05-06-2014 09:32:33
 Re: MM Hydraulic Cylinder ( in reply to Joe Pro, 05-06-2014 05:45:08
10A1840 Clevis piston rod 2 1/2 cyl. If you want to send me an Email and i will scan the page and send it to you.
lco9895@aol.com
Larry Mi
05-05-2014 10:42:49
Is this what you need
Larry Mi
05-05-2014 10:46:07
 Re: MM Hydraulic Cylinder ( in reply to Larry Mi, 05-05-2014 10:42:49
Well I'll try again
yonson
05-05-2014 17:50:22
 Re: MM Hydraulic Cylinder ( in reply to Larry Mi, 05-05-2014 10:46:07
Casting number on cylinder should be 10A79, just to clarify. 10A80 will fit but is sized for larger tractors.
Copyright © 1997-2015 Yesterday's Tractor Co.
