Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: mm u hydraulics
kevin moschenrose
04-27-2014 18:30:01
First question is "Are you using a MM hydraulic cylinder on your implement? If not that this a problem.
04-28-2014 17:26:58
 Re: mm u hydraulics in reply to kevin moschenrose, 04-27-2014 18:30:01
I am going to try the mm cylinder I have this weekend but am thinking the aftermarket check valve sounds like a good idea as It has perfect origin all paint. I need to go look at grandpa's old one to see if it has something like that on it. I still have it but its in pretty bad shape. I was wondering if there is a pressure adjustment on the u? It seems like I had to have the throttle up a bit to make it raise my disc.
Alan K
04-29-2014 22:29:28
 Re: mm u hydraulics in reply to jr1983, 04-28-2014 17:26:58
It might be that the intake screen in the reservoir is slightly plugged, but depends on what other cylinder you were trying, as it might be too small? See how the other cylinder works on it first.
