TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: G 1355
G1355
04-27-2014 17:34:29
Well if you wanna break even I'd give you 1500 lol, yes you gotta very good deal, don't know what you mean though on inside and outside weights, don't think you could put rear wheel weights on the 1355 that I'm aware of, they have a cast center piece in the inside, but don't see what your talking about on outside, can't tell does that one have battery box cover? I got one for mine. Looks good rather than that, can you post of the rear, just wanna see how fuel tank fenders are set, on outside or inside holes. Mine will look similar when done but new paint and 42" rubber and I will have about $30,000 in mine, got more expensive than I expected.
d21smith
05-04-2014 18:32:57
 Re: G 1355 in reply to G1355, 04-27-2014 17:34:29
IT RUNS!!!!!!!!!! Cleaned the entire fuel system over last week or so and on a temporary fuel tank got the system bled of air and she fired right up and purrs like a big kitten. i have discovered that my check valve in the small fitting on top of the injection pump is bad as if that fitting is on and the injection return line is on it the tractor will run for 10 seconds or so them die after several ideas i discovered if that small check valve is removed the tractor runs like it should but fuel is pumped out of the top is this normal? im not a professional injection pump man so im asking for any help? Now im going to install my new waterpump kit and see if that will solve the problem of water in the oil, if not im thinking head or head gasket? i hope nothing major as this tractor runs soooooo well. I went to move the tractor and the clutch is stuck any ideas as to how to get the big girl loose? thanks for the help so far and here is a picture of the rear fender placement..
d21smith
05-04-2014 18:50:40
 Re: G 1355 in reply to d21smith, 05-04-2014 18:32:57
Also my tractor has a 540 pto but looks like above that is a cover for 1000? Am I right if so is that hard to find or a rare option? Thanks again.
d21smith
05-05-2014 19:41:18
 Re: G 1355 in reply to d21smith, 05-04-2014 18:50:40
Bump
d21smith
04-27-2014 18:45:57
I'm thinking about a rops or canopy for this one are there any for sale?
MMDan
04-27-2014 20:34:56
 Re: G 1355 in reply to d21smith, 04-27-2014 18:45:57
Check www.saginawcountytractor.com for ROPS and canopy.
G1355
04-27-2014 19:00:36
There is a company that makes them for oliver/cockshutt, which would be the same since it has a 2255 rear end, they have a website I've looked at before but don't remember the name, they look the exact same as the originals
