TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: U-302 plow capability
mightymolinekid
04-27-2014 14:36:13
I left out a couple details, our U302 Super is the only tractor we have with 3-point and hydraulics. I can get this plow for little to nothing, but will need some time and money invested and I don't want to end up with a plow I can't use, nor will we buy a tractor to fit it either.
MMDan
04-27-2014 20:47:37
 Re: U-302 plow capability in reply to mightymolinekid, 04-27-2014 14:36:13
When my U-302 was my main tractor and I did quite a bit of plowing, I started out with a mounted 4-14 MM plow. Pulled it OK but a little heavy (used 4 front weights). I would think a 4-14 semi-mount would work fine if. Don't forget you will need to use a quick-hitch as you have top link draft sensing!
oliver fan
04-27-2014 18:50:31
The 3X16's have a total cut of 48" and a 4X14 will have a total cutting width of 56".
Go for it. Once you get the moldboards cleaned up, show the other guys how it's done.
Banditfarmer
04-27-2014 15:38:22
I had a Super U302 and when I bought it, It came with a 3pt 4x16 White plow. I plowed several hundred acres with it and it never had any problem pulling them. I guess it depends on your ground but I know mine pulled them just fine. Bandit
G1355
04-27-2014 15:22:27
If its really light sandy ground like you said it'll more than likely pull it, but you won't set the world on fire, I wouldn't try it around here with our heavy soil, we run a 2-155 white on 5/20s and its all it wants and its set at around 175-180hp
