Yesterday's Tractor Co. Affordable Parts, Just in Time
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
G1355 Power Steering Cylinders
newfarmer9
04-25-2014 20:31:52
24.114.57.147
How do you remove the front (vertical) pin on the power steering cylinders on a G1355? I have the rear (horizontal) pin removed, both hydraulic lines on each cylinder off, and the snap rings on the front (vertical) pins removed. The front pins need to go up to come out, however there is only a fraction of an inch of clearance between the top of the pins and the cast radiator mount.
I see there are large holes in the rad mount to the rear of the steering cylinders, however even with the tie rods off and the tires jacked off the ground I can't pivot the steering mechanism far enough back to push the pins up and out of the hole. Any help?
[Reply]   [No Email]
newfarmer9
04-28-2014 13:29:01
207.219.69.153
 Re: G1355 Power Steering Cylinders in reply to newfarmer9, 04-25-2014 20:31:52
Not matter which way I turn it, I cannot get the pins to line up with the holes in the casting. The pivot point always interferes with the front axle, and I am about an inch away from lining up the pins with the holes.
[Reply]  [No Email]
G1355
04-28-2014 13:44:41
67.224.60.152
 Re: G1355 Power Steering Cylinders in reply to newfarmer9, 04-28-2014 13:29:01
I took mine to buschers bros to get worked on, and I'm about positive Andy said you had to take off radiator but I could be wrong, I know he did in mine because the radiator leaked so it had to come out anyway to get fixed. I just remember him saying that about every g1355 and 2-150 power steering cylinders leak, and there no fun to get at and work on.
[Reply]  [No Email]
1923 Gleaner
04-27-2014 18:18:30
64.71.214.169
You do NOT need to remove the radiator. Get it turned right and the pins will go up thru the holes in the casting. I have done it many, many times over the years.
[Reply]  [No Email]
G1355
04-25-2014 21:07:12
67.224.60.152
Think radiator has to come out, they took mine out when they put in new cylinders.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
