Yesterday's Tractor Co. Tractor Parts for All Brands
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
G900 LP
Howard H.
04-17-2014 19:26:07
75.88.234.88
Hi Fellas -
I bought this prize jewel a while back from a long time MM family.
Both rear rims are shot from water, but other than that, it is a pretty straight & clean old tractor.
I haven"t ever seen a cab like this, though, that has a sliding door and I can"t find a tag on it. What brand would it be??
Also, I had been thinking it was number 11 of the first set of G900 serial numbers making it an early '67, but when I got it home, I realized it is 36300011 from the "69 year.
What is the difference in the serial # ranges? Why did they break them up?
Thanks for any info,
Howard
[Reply]   [No Email]
freddy
04-22-2014 18:10:50
99.151.34.210
 Re: G900 LP in reply to Howard H., 04-17-2014 19:26:07
Hello Howard, We have a G900lp also. Been a good tractor. Yours has closed center hydraulics so if I am right the earliest would be a 69 with the new MM prefix. They separated the LP from the Gas models. Our M670 Gas has the same cab as you're G900. On purplewave they are selling number 5 G900 Diesel. Engine is number 3.
[Reply]  [No Email]
MM diesel
04-22-2014 11:44:31
107.143.4.81
Another picture from the other side.
[Reply]  [No Email]
MM diesel
04-22-2014 11:41:58
107.143.4.81
Here's a picture of my G900 diesel with a cab of some type
[Reply]  [No Email]
Alan K
04-22-2014 21:55:35
208.83.187.208
 Re: G900 LP in reply to MM diesel, 04-22-2014 11:41:58
Weren't there some cabs that were "Full Vision" brand that were used in that time period?
[Reply]  [No Email]
shinnery
04-22-2014 00:55:25
216.189.193.198
Howard I think that is the same cab as on my G900-LP.
Send me an email shinnerytree at yahoo.com.
I am going to try to post a picture.
Bryce
[Reply]  [No Email]
maj-mm
04-19-2014 12:00:29
8.29.43.133
About those Front weights? do they have a part number on them? I've seen them, that shape in Catalogs & photos, but never in person. they are different that the other MM "Banana Weights" ~
Yes that is a Meade, "dealer installed" cab. Not factory, but Genuine "proper" for a MM of that vintage. I had a neighbor that had a M670 3-speed, with that cab. Other than filling Gasoline inside the cab, they are quite nice. Martin
[Reply]  [No Email]
ensbos
04-19-2014 07:44:34
166.181.3.88
Your tractor appears to be one of the later 69 G-900s with close center hydraulics. Someone one here will know the specifics. But if I remember correctly in Feb of 69 they changed a few things on those tractors hydraulics more inline with the 50 series tractors. You will notice the fenders are different that of a normal M670 G900 or G1000.It also has the 4 hole 50 series wheels, power assist external steering cylinders with the heavy front axle. It will also likely have the high mount alternator than is exposed instead of hid behind the front side tin work and no power sterring pump like a vista. The very very last ones had a three speed torque, making them essentially a g950 with the earlier tin work of g900. It also looks to have different heads and blocks, which is not unusual however 4 5/8 bore blocks and pistons would make the engine a 504 and the tractor basically a close center hydraulic G1000 or g1050 depending on which torque it has. That is why they had the serial number split, that is if I remember correctly.
[Reply]  [No Email]
Howard H.
04-21-2014 10:44:07
164.58.210.28
 Re: G900 LP in reply to ensbos, 04-19-2014 07:44:34
Thanks for all the info, guys!
I'll look for a weight part # next time I'm out at the farm, Major...
Yes - this cab is pretty neat with the sliding door on one side and a tall "butterfly" opening window on the other that would really let a lot of air in on a hot summer day!
I grew up on a couple of JD4020 lp tractors with Egging cabs - but I couldn't find a mark on this one anywhere...
Howard
[Reply]  [No Email]
ILL John
04-18-2014 17:28:20
108.68.170.85
I had a cab like that on an M5 also.
[Reply]  [No Email]
Ken in Illinois
04-18-2014 17:23:21
50.151.136.227
My 1967 G900LP (33000246) had this cab put on it at the dealership when new. Cab was made by Meade Co. of Meade, Kansas. It was used on other models as well. I like it other than noise levels. I have heard/read that in 1969 LP powered were given a seperate serial number range.
[Reply]  [No Email]
560farm
04-17-2014 23:16:02
70.194.96.87
I sold one several years ago with that same/similar cab and it was made by Egging in Nebraska. There should be a stamped plate up towards the roof on one of the side panels above the window.
Brad
[Reply]  [No Email]
Alan K
04-18-2014 06:48:51
208.83.187.208
 Re: G900 LP in reply to 560farm, 04-17-2014 23:16:02
I think those cabs were available for the M670 and G900s in 1968 or 69 weren't they? I think the first G900 cabs were more square up and down. I have some literature pictures I saved but they are on another computer.
[Reply]  [No Email]
Doug Cotton
04-17-2014 20:16:05
216.245.232.153
Looks like a MEADE cab we used to have on a 670.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
