MM T 160Baler
MM Turbo
Does anyone know where I can find knotter parts also missing the guard over the slip clutch.Who made it for MM my serial number book says Harrington did they make balers for anyone else?
If it has the New Holland knotters, parts are readily available. I think the only other knotter available is IH. Someone on here will correct me if wrong.
My book shows T160 was made by Long. Original MM part number 20P4433 is common only to MM not Oliver or Cockshutt models.
We've discussed this before. it is NOT a Long Baler. it was made by Harrington. What "book" are you referring to? they also built some balers for Long, so there is a chance some parts might interchange.
MM.com resources shows made by Long. MM T14,1520,1720,520,720 as well as 620 62T all use the 5CT 4036 needle. It crosses to 517 178 EC
MM T160 DOES NOT cross to any of the above. 20P4433 is only needle used. Baler is totally different. Must be thinking of the T14.
OK, those MMCI lists have MANY errors, just like the paint lists. the list I liked to is a copy of an actual MM Service Bulletin. It's information (albiet a few typo's) is most accurate known. I haven been expanding it for about 20 years, with additional Como, Louisville & other plant information not included.
I think that baler is the same as the Ford 530 when we used to have a T160 the spare parts sometimes were Ford blue.
