G1355/2-150 tach
G1355
Looking for a good working tach for a g1355 with a internal pump, its a cable drive tach, if you have one or can point me in the right direction that'd be great. I have one in it now from a 2255 but it doesn't read right, reads 1500 at idle and when you move throttle tach doesn't follow as should, will say its 3000 when its only half throttle, or if any other models would work let me know. Thanks
If you can't find one I'm sure a speedometer shop could build you a gear reduction for that one. I'm sure you can use any Moline tach and have one that reads correctly, but the 1355 used the Oliver type gauges.
Well I have the old one, but it didnt run off a cable it ran off alternator, which oliver models work, would a 1855,1955 etc?
Original tach is 30-3086461 used on 1355,2270,2-105,1350 and A4T's. Adapter to motor 10A19219 used on 2-105,2-150,1050, and G950.
