I have noticed anti-freeze collecting on the left side of the engine, in the top edge of the crankshaft side cover, just below the water intake manifold, as well as very slowly running down the side of that cover. It is a slow leak and I cannot figure out where the coolant is leaking from. It does seem to start showing up at the base of, and near the center of the two cylinder blocks. There is no sign of water or coolant in the oil. I would appreciate any suggestions anybody may have about where the leak may be coming from, since I am guessing this is not an unusual situation with these tractors. What is the required repair?
Also, is it going to be OK to run the tractor this way, or do I need to make the repair before using it again?
Thanks very much.
Thanks very much.
