Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Help
03-27-2014 10:08:16
Well we are grasping at straws here, and this is probably a stuipid theory. I have not studied the possibilities. Is it possible that the cam is 180 degrees off, and due to the firing order 1 & 2 are working, and 3 & 4 are way off base????????? When you get to the end of the rope make more Rope.
03-27-2014 13:00:42
 Re: Help in reply to MMDEL, 03-27-2014 10:08:16
Ha!! Agreed on the rope. I took these pics today to show the timing marks. I put some white stuff on the crank gear to show where the tining mark is but the mark shows up well. You see the O on the cam gear. These two marks don't match up exactly but as close as I can get them. You can see the cam gear marks on a tooth and the crank gear marks on a tooth. These marks can never match exactly. Is it possible I have the wrong crank gear? that's the one I replaced.
03-27-2014 15:57:36
 Re: Help in reply to dkr, 03-27-2014 13:00:42
36 tooth crank gear 72 tooth cam gear. Timing mark 180 degrees from 0 mark on cam gear.
03-27-2014 18:05:52
 Re: Help in reply to molinepuller55, 03-27-2014 15:57:36
Crap, so I possibly have it 180* out. That O was the only mark we could find on the cam gear. I'll check it again tomorrow. Thanks.
jd plowboy
03-27-2014 15:32:24
i was told that there should be a line back from the zero and that should be lined up with the line on the crank gear. also the gear needs to be a 36 tooth on the crank and a 72 tooth on the cam. try this and see if it helps
