M602 spider pinion shaft
ChrisQ
I am helping some friends of mine with their M602. Thanks for the bull pinion Jeff, we may need more stuff yet. The problem now is the steel pin that holds the locking pinion for the spider gear in the carrier will not come out. We tried pounding it from either way with no luck, and also tried a little heat to no avail. Today we tried drilling out the pin, but the access hole does not line up close enough to drill it, And there really isn't a lot of room inside. Just wondering if we should cut the bull pinion and shaft that goes through it? Or if anyone else has ever had this problem? Thanks for the help in advance.
