G1355/2270 Hydraulic Pump
Where is the hydraulic pump on a G1355/White 2270 located if it has an external pump, and does anyone have a picture of the external pump? What is the cost to replace a hydraulic pump internal vs. external?
Thanks!
2270 has hydraulic pump located on left side of transmission housing as all Oliver/Cockshutt did. Only part of tractor that is MM is 585 motor. External oil pumps were added on all 1355/2270 's due to motor failure on early models.
If it has a external pump you have spin on oil filters, if its
internal the oil filter is in the oil pan, easiest way to tell
Are you asking about the bleeder/ cooler pump? If you use the late external pump for the engine you have to change other pieces Call me more than I want to type 812
-2345-1301
Go over to the Oliver page and scroll down to the post about 1855 gas tractors. The picture of the 1855 gas shows the hydraulic filter and the lines from the pump right behind the filter. The pump is a Vickers Piston pump. You can buy them new, rebuilt or you can rebuild them with a new rotating group. Before you buy a pump you need to trouble shoot the system properly!
