Moline UB piston rings
rmf1066
I'm having a hard time finding a set of standard piston rings
for my UB. Does any one know of a place on line or locally that
might be able to help. The oil ring is .250 and the comp is
.156. I'm also going to need a set of rod bearings and they
seem as hard to find. Maybe I'm just simply looking in the
wrong place and my local parts store don't want to dig deep
anuff. Thanks.
You're on the net, go to Hastings piston rings, go through the applications until you find yours. I think it will be Hastings set #2C7743 for 4.25 bore 5/32 compression and 1/4 oil. jack
Thanks for the help. I just ordered a set. I never thought that the MM were that much harder to find parts for( I guess I just haven't found there hiding spots yet) then the ih's I'm use to. I had found all the part#s that I needed but none of my local part stores and local Agco could not them.
Most parts were readily available up to about 5 years ago then things started to thin down some more. They are out there just a matter of finding the right place and right person.
