Moline tractor values
Anonymous-0
I had the pleasure of meeting someone last week that bought a farm that has 5 moline tractors on the property. We went and looked at them all this past weekend and I wanted to get other opinions on the values of these tractors. #1 is a G1000 Vista diesel with a factory cab and factory dual cone hubs.Has been sitting in a barn for a period of time and they do not know the last time the tractor ran.2 speed ampli-torc and 8 bolt front rims. It has 18.4x34"s that the rims are rotting out on. #2 is a 335 gas that they used up until last fall when it quit running. Has a re-cored radiator and new back tires. Tinwork is straight and fenders are good. Torc and PTO seemed to engage as it should. Nice little tractor. #3 was a 5 star gas that has been sitting outside that has not ran in some time. Has the 283 as it should, tin was straight but the tractor was rusty. The pto lever does not work as it should and does not have any distinct "Snap" in to either position. Rims and tires seemed okay and it had a schwartz wide front. #4 was a ZTU sitting outside next to the 5 star. Similar condition and has also not ran in some time. #5 is a G1000 vista open station that had a 451 diesel engine in it with a turbo. I do not know exactly what it had for a torc because the normal lever that is usually there was not. It had 18.4x38"s and if I remember correctly one rim was rotten. 8 bolt fronts, tin was straight and it also has the bolt on dual hubs. Tractors are located in NY.
Vista's are about $3000-$10,000. There are lots of unique parts on a Vista.
335's are about $1500-3000
ZTU-$500-1000
5 star $600-2000
Can you post a picture of that g1000 with the factory cab, would like it find my dad's old one back and there isn't many around just like to see it.
