Chuck / MI
New User
Been hauling / feeding hay all winter with tractor, getting around fairly well with chains (till the snow got too deep). Tractor performing well, no issues at all. Couple days ago had tractor warmed up; drained crankcase & dropped oil filter and went in for lunch while draining. Hour or two later, new filter, refilled (a little too much), started engine: no oil pressure. Since then attempting to verify pressure while cranking engine, no spark plugs: changed gauge (same result), removed press sensor line at oil pump, no visible pressure while cranking, removed oil filter (filter had not filled with oil). Cranked engine without filter on, oil does pump out the port. Installed new oil filter. Drained crankcase oil, put in lighter oil. Still no pressure while cranking with starter. Filter still does not fill with oil while cranking engine, but with oil filter off, cranking engine does pump oil out port. With everything normaled back up, started engine. 30 sec. at idle should've filled filter & built pressure but did not. Shut down. Cannot figure out what is going on here. Oh, and tractor has not been in a warm shop; ambient daytime temp has been in teens & 20s F. Anybody ever encountered anything similar?
