M602 bull pinion gear
ChrisQ
I am helping a friend fix up his M602 diesel. We got the hydraulics removed from the tractor and the left side bull pinion gear, I believe it is called, (small gear that brakes run on and drives bull gear) is extremely chipped up on most of the teeth. The bull gear seems to be okay. In the parts book for the M602 there is no part number for the gear. Does anyone have one, the part number for one, or know if M670 or M5 ones would be the same? Thanks for the help.
From what I found for the part number is 11B8248 Sleeve-Bull Pinion (reference #15). Im guessing it is the whole shaft with gear and it is all one assembly. As MM Diesel said, M5 M602 and 5 Star, Part number is the same in the 5 Star, M5 and M602 books. There should be a few of those around somewhere.
