UB brake/stub shaft
KLS
Does anyone have a brake/differential shaft for the right side of a UB or U with disc brakes. I have a fencrow find that someone gutted the live power on and aparently took out the shaft from the right side too. Thank you
I have the internal parts to put live power back in. To delete totally you will need the correct LEFT brake housing. right housing won"t fit. Pinion drives from right will fit left side. Correct left brake housing is hard to come by.
