Head for M670 Super
JHH
Have a M670 Super apart that sat for a couple of years and was stuck. Back head was cracked between the valves and repaired and apparently still leaking. Looking for a good replacement head.
There will be a casting number between the spark
plugs. Need to know what that is and I should have
a replacement for you. Price depends on what the
number is.
308-940-0255 Jeff
(quoted from post at 10:28:32 02/02/14) There will be a casting number between the spark
number is.
308-940-0255 Jeff
Sorry Jeff, This is a diesel.
The bad head is casting # 10A23134.
The good head is 10A29559.
Spoke with G1000 MFWD on the phone and learned that these heads use different injectors.
I have 4 - KB95SA485/13 injectors, in which head are these correct?
