Moline Reproduction Sheet Metal
Tessman Tractors wants to assist you with your restoration project. We are initiating the development of replicated sheet metal based on original factory prints.
Are you interested in...
M-5 fuel tank side pieces?
Oliver 3-digit rear panels?
UB Special power steering covers?
U Moline right-side hood panel?
UB Special side panels?
Or...Specify other sheet metal you"re interested in.
Do you do complete restorations? Where are you located? I have a M5 that needs to be restored and I do not have the time.
I'm not currently needing anything, but I think some good sellers would be the nose bands for M602, Early U302 and Jet Star 3's, possibly others. Also seems to be a call for the rear side panels for Jet 3, U302, M670, G900, G1000s. Just my thoughts
Yes, U right side hood panels would be a good reproduction item. Especially those with the louvered sides would be nice to have. And the MM plate for white band MM's .
I've been looking for some good GTA side panels for quite a while, but think I've finally found some...
Not sure what the demand would be for them...
Howard
Fenders, Fenders, Fenders!
Just about every set of clamshell fenders I have seen on unrestored MM tractors are beat to hell at the back or tore up bad. I imagine the standard fender found on the Twin City models and early MM"s would be in demand as well? I need a set for my FTA.....
The Minneapolis-Moline side badges, and the MM, and Minneapolis-Moline front badge for the U 302 thru G 1000 I would think would be in demand. I have not found any sources for those.
would be interested in some aluminum lightweight fenders for the U, UB, and G series if the price was not to outrageous
The front MM for the 50/55 series can't ever find them and there's a lot that are misssing. Also I think if someone could find out how to make oliver/MM fuel tank fenders that'd be neat and the end caps as most are all beat up and the cast blocks that sit under neath them.
U and UB right side hood panels - at a decent price these should be a high demand item - every U / UTS / UB I've ever seen - other than LP - has rust / burn thru problems ranging from minor to completely in 2 pieces - I personally would buy 2 each with and without louvers.
Ditto on the R.H. U and UB side panels. There was a guy in southern MN making complete U hoods and side panels about 10 years ago, but I believe I heard he quit. Arne Lillo? Does that sound right???
We have the hood panels and hood for Jet Stars, 445s and 4 Stars, 920 295 3278, riverdalefarmshop.com
We have the MM's for the U302's, 602's, etc. that hold the lower white bands in front, 920 295 3278, riverdalefarmshop.com
I appreciate all of the input that has been posted. This gives me a better understanding of what people are looking for. Please continue to post all other preferences you have. Thanks, Mike
I think that Stamm tractors have almost all of the stuff listed on here... maybe should give them a call.
