Jetstar hydraulics
I have a Jetstar 3Super. I recently removed the hydraulic package to work on the PTO clutch. It went back into place with no problems, but since then, I have getting the lift arms to lower. They raise as they should but it's hard to get them down. Sometimes playing with the depth control helps but it's still a slow process. Ideas?
While handling the system you may have inadvertently moved the rate handle under the seat toward the lock position.
john
