1951 UTU Propane Battery box
This is a picture of Dad on his utu in 1951. Shows battery box on left side behind inspection plate to grease throwout bearing. I hope this may help you.
Well that is a battery box.
But I am thinking the factory tray was a plate with turned up lips on 2 sides and used the same end clamps as when the battery was under the gasoline tank.
I got one from Wendell Everett (740-922-3335) so I could use a regular car battery on my '49 UTS.
This box was built new off of dimensions of old corroded box.
Brackets are factory.
When tractor was new it was a long 6 volt its now a long 12volt
Tony
