TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 50/55 series side weights brackets.
Triplelpaints
01-13-2014 05:06:17
I had a set made for plowing this fall since my G1355 is a little light in the nose with the 5-18" rollover plow on the hitch. Worked out well, tho never got to try it in the field. Road travel was the main concern and it kept it planted. There really isn't much to them, I just punted with what looked right and installed them on the tractor. They mounted to the most forward set of the 4 3/4" bolt holes under the radiator that secure the frame rail to the steering assembly
G1355
01-13-2014 05:13:15
 Re: 50/55 series side weights brackets. in reply to Triplelpaints, 01-13-2014 05:06:17
Can you post a picture, haven't seen any good close up pictures of the,. Thanks
Triple L Paints
01-14-2014 12:01:06
 Re: 50/55 series side weights brackets. in reply to G1355, 01-13-2014 05:13:15
Heres a couple pictures of what i had done to mine, not sure if its correct, but its functional and looks correct enough for me
j meyer
01-15-2014 04:53:30
 Re: 50/55 series side weights brackets. in reply to Triple L Paints, 01-14-2014 12:01:06
The original ones curve and that large flat steel on the end is considerably smaller- they surely will work, but won"t pass for originals! Looks to be some nice original paint on that G1355!
mab570diesel
01-17-2014 03:25:15
 Re: 50/55 series side weights brackets. in reply to j meyer, 01-15-2014 04:53:30
sure does look like a real nice "survivor"
G1355
01-14-2014 17:14:05
Thank you for taking time to post pictures, now I got a good picture and can see how they mount. Not sure how the original ones look but those look good enough to me, and if I can't find a set that looks easy to build. Thanks again for the pictures.
