Hello I am looking for a complete motor for a Model 5 BF Avery. Bought this one years ago and does not have a motor so I am looking kno if you might have one let me know what you want I am up in Evans WA Email is [email protected] Thanks Dale
I'm not familiar with the Model 5 designation but my 1952 MM BG has the Hercules IXB3SL 4 cyl gas engine. I have a block and a few engine parts (condition unknown)for a MM BF. Your best bet will probably be Bill Williams, Baldwin, MS phone 662-728-3747. I have an email address as [email protected] but I don't know if it's good or not. He has a lot of Avery, MM, White and others. Good Luck
I forgot to add: I have an original Owners Guide to the MM BF and Avery A. Both use the Hercules engine in my other post. My MM IT manual lists Avery A, R, V and MM BF, BG, V but no model 5. The tractor serial number should be on the right side of the frame where it bolts to the final drive.
Thanks for the info I had no idea where the SS no was This thing has a V4 Wisconson in it know and is froze up I would like to at least find out what one will cost The little tractor has a Model V cast in to all the parts Thanks Dale
sounding like a model V Avery, the serial # will be stamped into the top of the righthand rail in the area of the bellhousing. The V is a small tractor like the Farmall Cub. Smallest Avery/MM, the serial # will be something like 4V????, 5V, 6V, or 7V???? A picture would be lots of help.
You mean Roman Numeral 5?
We call that a model "Vee" as in the alphabet letter "V".
The only person I know who can help with a complete engine is Bill Williams, but he is in Baldwyn MS. I do not have his phone number.
Those engines are Hercules model ZXB and they were used in other equipment besides Avery tractors. I know I looked at one in a Military application power unit about 20 years ago.
Another source may possibly be Postma Brothers in Linden WA?. They were a MM dealer, I think.
