UTS brake lining thickness
If you have 6" disc brakes they're 3/16 , if you've got drum brakes the JT9170 linings are 1/8 inch.
Thanks. I have drum brakes and the parts manual calls for JT 9170 linings. The brakes had been maladjusted so that only a bit over half the linings were in contact with the drum. The unworn end is definitely thicker than 1/8" which most likely explains why the adjuster was completely unextended. I reckon the wrong linings have been fitted.
Jack
There is a set on ebay if you search the buy it nows or probably Agco , have not bought a set for a couple years now .
Got a set from Moline Parts. Will still be cheaper than having roll on linings bonded locally even with shipping to Australia.Thanks for all the help.
Jack
