Anonymous-0
HELP. I have a 1961 MM (brown)Jetstar. I'm having trouble with the starter. I've had it checked twice by a good starter man. New brushes, new starter drive, new switch. etc. It always checks out good by him. When I install it, usually starts once or twice & then jams. Sometimes against the flywheel, sometimes at the end of the stroke. The ring gear is far from new, but not all that bad. I even filed a little on some of the teeth.. I also rotated the flywheel by prying a few times & this does not help. I understand that the engine usually comes to a stop in about the same place. The engine in this tractor runs perfectly and when the starter engages, fires instantly.. I am frustrated & ready to give up.. Any ideas. This starter gear has 12 teeth.
