TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Jetstar starter trouble
mrpete2
01-04-2014 10:15:16
HELP. I have a 1961 MM (brown)Jetstar. I'm having trouble with the starter. I've had it checked twice by a good starter man. New brushes, new starter drive, new switch. etc. It always checks out good by him. When I install it, usually starts once or twice & then jams. Sometimes against the flywheel, sometimes at the end of the stroke. The ring gear is far from new, but not all that bad. I even filed a little on some of the teeth.. I also rotated the flywheel by prying a few times & this does not help. I understand that the engine usually comes to a stop in about the same place. The engine in this tractor runs perfectly and when the starter engages, fires instantly.. I am frustrated & ready to give up.. Any ideas. This starter gear has 12 teeth.
mmfan
01-08-2014 05:15:48
 Re: Jetstar starter trouble in reply to mrpete2, 01-04-2014 10:15:16
This has the single bolt that holds it in correct? Does the starter fit well in the machined bore of the block? If it moves some that can cause it to bind.
jnf
01-05-2014 09:29:03
My problem was with the bendix drive not fully engaging the ring gear.
Alan K
01-05-2014 09:22:13
Just thinking outloud...does it have a solenoid or a starter button ontop of the starter? Not sure if there might be a problem there or not.
mrpete2
01-05-2014 11:49:59
 Re: Jetstar starter trouble in reply to Alan K, 01-05-2014 09:22:13
No solonoid & switch is brand new.
jnf
01-05-2014 04:11:07
I know your frustration. I had the same problem with a U. It also had a new drive. I had a second man look it over and he identified the problem and has not given any problem the last two years. Sometimes a second look by another man may help.
matthies
01-05-2014 07:44:13
 Re: Jetstar starter trouble in reply to jnf, 01-05-2014 04:11:07
Do you remember what the problem was? thanks chris
