Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: U302 3 pt lift update
01-02-2014 17:25:05
I had the gauge in the #1 port. The manual said to put the gauge in that port, and hold one of the levers back long enough to get a reading. I tried that and could not get a consistent reading. I tried raising the 3pt and got the 170psi reading while it was raising. If the pressure relief kicked in the gauge would peg at the highest setting. This is my first time working with a hydro system. Any help is appreciated. I just don't want to damage the pump, but would like to be able to have it working correctly to lift the new/old plow.
01-02-2014 17:56:30
 Re: U302 3 pt lift update in reply to Scout2008, 01-02-2014 17:25:05
Got ya. It was worth a guess. What is the maximum pressure on your gauge? Sometimes the relief valve will cause the gauge reading to "jump" making it difficult to get a clear reading too. Especially if you are nearing the maximum pressure reading of your gauge.
You may need to wait till warmer weather to set your pressure. Cold oil can give you a high reading. Pretty awesome that your pump is still able to develop higher pressures.
01-03-2014 03:43:35
 Re: U302 3 pt lift update in reply to Klw445, 01-02-2014 17:56:30
I am trying to figure out if the relief valve was my lift problem. Could it have either been out of adjustment, or the spring gotten a little weak, which cause the relief valve to kick in before it normally would have? In my uneducated mind that would make sense after making a minor adjustment to add tension solved my lift issue (I think). I did think about the fluid being thick due to the cold. I tried to warm it up, but this time of year it"s a little tough (-3 this morning). Thanks for your help.
